Graphic equaliser for Win 10
22 Nov 2012
My pc has a 2.1 speaker set up which is rather bass heavy.The audio is provided by VIA HD 20H2.
Is there anyway of adding some tone control or a graphic equaliser ? There is nothing built in.
Thanks
+1 for EqualiserAPO, a bit of a faff to initially setup and configure, but actually once installed it just seems to work!
I've installed it,wasn't difficult at all lol.
Do I need to start it every time a boot my pc ?
Ignore that I see you can set that in the settings.
Cheers guys
I tried APO but it just would not work with my setup (yes, I tried a lot of troubleshooting options and googling).
I ended up buying Boom3D and it. just. works. :D
Very happy - can finally get the balance right between bass / mids / treble. Since I'm just using a budget-ish 2.1 setup, the mids and bass are much too heavy and treble lacking.
Music sounds like it should (or damn close) to my Sennheiser SP25 / NAD / Dynaudio setup.
APO is system wide. Not sure how it couldn’t work.
At least you found something.
