Graphic equalizer settings for bluetooth headphones
5 May 2004
Hi all
got some bluetooth headphones for my laptop and they need tweaking a little soundwise i tried the realtek equalizer built into windows but as i guessed this will not work with bt headphones.
are there any apps out there that are free and decent ?
i did use the small settings in windows management but tbh u only get 3 options which are of no use .
You want APO Equaliser and the PEACE UI front end, both open source.
It's a bit OTT, but most audiophiles find it acceptable..
