Hi
Very very rarely either when my pc boots up or when the monitor wakes from sleep the colours will be....strange, it will look normal except some oddly coloured blocky areas of the image usually appearing where there is movement on screen or where the colours are bright (for example on youtube the shine on someone's forehead would be covered in bright blocky purple).
The last time it did this i took a screenshot and pasted it in to paint and it replicated all the 'glitches' in the screenshot just smaller of course. I then turned the monitor off at the button and back on again and they were all gone including in the screenshot on paint.
Its very difficult to replicate as it'll do it once in a number of weeks so i can't really pin point what it is or if its graphics card related of monitor related.
I have changed the displayport cable to a vesa(?) Certified one as the one provided wasnt great but it has done it since so its not that.
Anyone else had this issue? Its connected to a 2080ti via DP running at 1440 144hz with gsync on.
Thanks for any help
Thanks for any help
