Graphical Tearing
2 Mar 2006
The Wirral
Hi recently i have been getting graphical tearing in some of the games ive been playing. Mostly in CSS and other source mods. Below i have included an example of what i mean.
My System spec is
P4 3.01 Ghz W/ HT
Nvidia7900GS
80gb HDD
2.5gig ram
nothing is overclocked nor has been.
my card temps are about 59 idle and 67 under load.
i have the 94.24 drivers installed.
hopefully you guys can help me out :D
i had the 158.27 drivers installed before and just installed the 94.24 ones a few hrs ago to see if that made a diffrence but it didnt :( sry should have said that in my first post.
yeah ive tried V-Sync on and that doesnt seem to do anything at all. i will check to see if thers any new drivers also
Try running ATItool and use the scan for artifacts feature. If it doesn't find any then it might not be the card.
Jokester
i did the ati tool and it apparantly found no errors but beeped.. this is what it said.
anyone know what that means?
Jokester said:
It's found some errors, that yellow dot just below the middle of the cube.
Jokester
hi
just running ati tool myself as i have a few probs....the cube stopped spinning straight away and its constantly beeping but say no errors. :confused:
neil27 said:
hi
yeah thats what happens on mine when i run ATI tool :(
The cube does not apin when stressing but the beeps normally mean its found errors, it can have lots of yellow artifacts and not count them as errors, I use prefer to use my eyes.
