Hey Guys,
Basically I fixed up my system in March of this year and have been playing games on it fine up until about November when Far Cry 2 was released, I updated my graphics drivers, started playing and all was well until my screens shut off and then 5 seconds later, blue screen and Nvidia display error. I recently reverted back to my older drives and as much as that didnt fix far cry, it did resolve my other games that had started to crash due to the drivers.
I started to monitor the temperatures of the system and I have now noticed when playing the 'bigger graphic hog' games the temperatures are exceedingly high. Take for example tonight I was testing Tomb Raider, I played for around 30 mins and my graphics were hitting 99 degrees, I know the card can run stable at 90 but nearly 100? Surely not good. So I removed the side panel to let a bit of air in, and it actually dropped 15 degrees! I played for a further 2 hours and the temperature remained 79-84 max with the side panel off with no crashes etc. I've yet to test Far Cry 2 but I imagine results will be similar. My questoin is, why is my pc getting so hot with the case I'm using, and what would you recomend to help cool it, I'm using the stock graphics cooler but tbh not sure I want to tamper with it too much. I used to run games such as Crysis btw with no issue with erros etc, and I cant say I monitored the temperatures so I cant really compare what they used to be like. I dont really want to leave the side panel off all the time, but 15 degrees is quite a massive difference.
My System
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
Gigabyte GA-P35-DS3 (Socket 775) PCI-Express DDR2 Motherboard
G.Skill 4GB DDR2 PQ PC2-6400C5 (2x2GB) CAS5 Dual Channel Kit (F2-6400CL5D-4GBPQ)
Coolermaster RC-1000 Cosmos Silent Full Tower Case - Black (No PSU)
Using two monitors 28" 1920 x 1200 and a 22" 1680 x 1050.
Cheers for any advice
My System
However Scythe fans are decent, for moving air then>
), I remember installing one fine before on an old system but just could not get my head around why they were not working. They are all powered on and the lights flash up on the controller but I may have them set up wrong.
