hi i dont think it does post the lights are on, the card is a 8800 i dont know the brand of it, i know its nothing to do with reseating ect or psu, so i am assuming there is a physical problem with the card, i have another exact same card with the same problem both are not from my system..
yes they were in an old setup from ebay
do you think the card may have dry solder joints or a reflow might fix it maybe..
