Graphics card advice please
31 Jul 2009
My specs are ASUS motherboard M4A78
1. T . sata hard drive
4gig corsair xms2 memory
AMD phenom X2 11 black edition cpu
samsung dvd drive
OCZ StealthXStream 2 700W Power Supply
win.xp
I would like to upgrade my graphics card which is a Sapphire Ati Radeon
HD4890
What would be a good choice to see a real difference from my HD4890,
or would CPU upgrade be better? I use pc only for gaming .Budget about £200. Cheers.:p
Thank you,on your opinion would it be better to go for the cpu upgrade or the graphics card,I cant do both.I usualy play games like ,CIV. 5 Total war games ,simulations and strategy games.
480 FT W!!!
But obviously, CPU would be a bottleneck a lot of the time. Have you got one that unlocks to a quad core? IIRC, some duals unlock to quads
If you take my suggestion, you can do both! It stays within your £200 budget and the 5850 is still an amazing graphics card. Instead of a 5850, you could get THIS
It can handle all those games. If you're a flights simulator fanatic, then I would recommend an Nvidia card as they perform better in FSX. http://www.overclockers.co.uk/showproduct.php?prodid=GX-156-OK&groupid=701&catid=1914&subcat=1341
With a CPU, that will go over budget but you can always sell your old stuff for over £50.
You can also get THIS and the CPU i recommended in post number 2
Just saw on another site that it might be a bit pointless upgrading whilst I only have windows xp,as I wouldnt see much improvement unless I got win.7 I would appreciate any comments.
