Graphics card advice.
15 Jun 2011
Hey everyone, first time post.
So I recently bought a Titan Krypt, but I didn't have the cash to bundle it with a graphics card upgrade. I'm a motion graphics designer and graphics cards arn't as important as RAM and CPU for me. However I have a bit of cash now and was wondering if anyone could point me in the direction of a suitable card upgrade up to around £60 - £150. The onboard card is nvidia geforce 7025 I believe.
Its my first desktop in a long long time so I'm not too clued up on components.
I hadn't intended on using it for gaming too much but It would be great to be able to run games like the witcher 1 and 2.:o
Welcome to the forums!
I would get the 5850 ;)
There aren't many other cards in the price bracket that will come anywhere near. It may be worth spending a bit extra and getting the XFX 5870
2 votes for the 5850.
Also forgot to add that you should have no worries playing the Witcher + Witcher 2 on max paired with the Phenom II X4
Thanks for the advice guys, would it be hard to install the 5850? As the onboard card is nvidia would I have to remove that somehow :o? Or just fix in the 5850 and let it install the drivers and get going?
^^All you need to do is uninstall the nvidia drivers, switch off pc, install your new card. Switch on and install amd drivers.
Any of the two above cards would be great, heres a comparison:
http://www.anandtech.com/bench/Product/295?vs=313
Stock for stock the 5850 looks a bit better, but if you want to get your hands dirty and do some overclocking, the 460 may be a touch faster if it's a good clocker.
Thanks for the really good advice fellas, I just placed an order for the 5850. Hopefully it should be a good little boost for some of my work software, and I'll finally be able to play the copy of the witcher thats been sat on my desk for the last month!
