- 14 Aug 2012
Hi,
I'm looking into buying a new gfx card and possibly changing from nVidia (GTS450) over to ATI Radeon HD. (unless someone can convince me otherwise).
My budget is around £200 and so far i am looking at various 7850 and 7870, hoping to buy the best card MY money can afford (not interested in additional games included)
The choice of card, manufacturer and spec is confusing and i just don't know what to go for. Some seem to run from 850-1100Mhz as stock.
So questions, what would you go for:
7850 vs 7870 vs. other similar (and different variants)?
Manufacturer: Asus, gigabyte, Sapphire,...
Benefits of this card?
Does it run OK with Intel processor?
My mobo is an asus p8p67pro running intel i7-2600K @3.4 Ghz
I read that these cards run on PCIe Gen3 (which my mobo doesn't have).
Will this be an issue?
Thanks for any help or advice you can bring.
Cheers!
Cheers!
which IMO makes the 7850 less appealing considering the 8-10% performance gain and price differential.
