Graphics Card Advice?
1 Sep 2012
Hi i have about £120ish pounds maybe more i would like a new GFX card better then my current OEM GT430 as its started dropping frames in cod4 and stuff im looking for a card that will run it 250+ fps on low settings in 1920x1080. my current system is a : amd phenom II 965 8gb 750watts psu gt430!
many thanks!
what do you mean its started dropping frames.. you mean it didnt before?
assuming its not overheating (check for dust in fans) then a clean driver or windows install should get you back to full speed.
not sure on current prices but 2nd had 560ti would be a nice one.
