- 6 Jun 2011
Hi all,
I built this machine about 18 months back based on advice on here and planned to add a graphics card in down the line. So far it has served me very well. However I think the time has come for me to finally add some graphics in but I could do with some advice on what card to go for if anyone can help.
Here's my current spec:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM
Asrock Z68 PRO3 Intel Z68 (Socket 1155) DDR3 Motherboard
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX)
Antec High Current Gamer 620W Power Supply
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366)
I'm wanting it to be able to play games in as high quality as possible. I'm probably looking at spending around £150ish although I may be persuaded to go closer to £200 if it is really worth it. Is now even a good time to get a graphics card?
From what I remember there isn't a great deal of space between the cooler and the graphics card slot on this board so that will no doubt come into the equation.
Hopefully you can help me out. Cheers.
