Graphics Card Advice
20 Nov 2013
Hey guys my mate at work has asked me if i would like to swap my 8800GT 512MB card and £20 for his gainward GTX 260 896MB. can anyone tell me if this is worth it. thanks
this is my system is around 6-7 years old now, i have added 4gb of ram and i cant really afford any major upgrades now due to having a family. i use my system for mainly gaming -( world of warcraft,league of legends,football manger)
There both very old cards now.
http://www.hwcompare.com/1688/geforce-8800-gt-512mb-vs-geforce-gtx-260-core-216/
The comparison shows it is an upgrade, but im not sure your mate is been that good to you.
Whats the rest of your system? Might you consider putting in a bit more money for a more modern card?
What do you use the system for?
I assume you play at 1080p resolution. You will see some improvement going from the 8800GT to the 260. I did the same when I was using a Q6700 and it was a reasonable jump. You won't be able to play any modern games with any sort of high/ultra details at reasonable fps though. Even for wow, if you raid, that system will cause fps drop issues unless you turn settings right down.
