Graphic's card advice
19 Dec 2013
So my build is slowly starting to die on me after 4 years so i thought it was time to start upgrading and I thought I would get the most expensive part out the way at the beginning.
My budget for a GPU is £550, £600 if needed (planning on getting a second card in November when I have some more spare money), I was looking at the GTX 780Ti's but now that the 980's have been released I'm not too sure which to go for or which manufacturer.
Some more info if you need it. I run a triple monitor setup and the new build I am planning is an i7 4790K, H80i (case I have doesn't fit the H100i), Asus Sabertooth mobo and everything else I will be using from my old build.
My budget over all I am thinking about £1,500-£2,000 so any opinions on cards would be appreciated.
