- 24 Apr 2013
Hi there, I'm pretty new here and to having a pc that can actually do anything.
I've just got a pc with a ATI radeon HD 5700 series graphics card which has 2 DVI ports and 1 HDMI and something else I've never seen before.
Here's the problem, I have 2 HD TV's and I'm trying to use my pc with HDTV one. However nothing shows up when connected to both hdmi ports on the tv. The pc works ok on HDTV two but takes about 100 restarts and several punches to get the TV to pick up a signal, I've also tried using a dvi to VGA adaptor am connecting the pc to both HDTV two and a seperate VGA monitor which just doesn't work at all.
Can anybody offer any advice or anything to try?
Thanks in advance.
Thanks in advance.
