As per the title, what would you go for for a bit of light gaming and some reasonably complex CAD/ Design work?
I don't need a super precise pro card for the kind of work I do.
I'm running 2 x 22" monitors, not HD but they're decent Dell models.
The spec I'll be soon running (when the bits arrive) is i5 2400 (standard) on H77, 8gb ram, sata II SSD and my old GPU an fx1400 (bet that takes you back)
Nothing fancy in games, I want to try Amnesia out, may give Guild wars II a try when it comes out at the request of a mate.
