Hi guys
Something has broken hoping you can help...
I have a Dell 24" monitor connected to a HD7850 via DVI. I turned on the PC last night and there were green lines patches over the startup screen and then the windows boot screen. I then wasn't able to get to the windows login screen (i think it's blue screening but I can't see it). I was able to boot into safe mode and login to windows (still with weird lines on the screen) but following this could still not boot into windows. I've managed to uninstall the AMD drivers etc. but still no effect.
Upon removing the graphics card I hooked up my TV to the HDMI port on the motherboard - all working fine. Put the graphics card back in - same problem still there. I'm also unable to get any output from the HDMI port on the graphics card (can't see the bios startup screen for example).
Unfortunately this stupid motherboard only has HDMI out so I can't test my monitor hooked up to the motherboard to rule that out. I will try hooking the monitor up to another PC tomorrow and also try putting another graphics card into the PCI-E slot to see if that works.
Is there any other diagnostics I need to do before conceding it's the graphics card that's died i.e. could it be a memory problem?
Will attach pics, thanks for your help.
EDIT:
video in safe mode: http://tinypic.com/r/nox7o0/8
bios photo: http://i57.tinypic.com/b5inmr.jpg
safe mode logon: http://i60.tinypic.com/2u5xs02.jpg
EDIT:
thought as much.
