I'd be grateful for some graphic card advice.
I'm currently in the process of sorting out a new pc build. It will have to last me for at least 3 years. It will be used for gaming. Mainly CODMW series, BF3 and other FPS games. It is also used for on-line racing using iRacing.
Current system uses a HD 5700 series though a TripleHead2Go into 3 x VGA only monitors. Max res of each monitor is 1280 x 1024, so in 3 screen mode 3840 x 1024. I do not have the budget to change the 3 monitors.
System plan at moment is as follows:
MSI P67A-GD53(B3)
i5-2500K
Be Quiet! Dark Rock Advanced
Antec TruePower New 650W
Fractel Design Define R3
2 x 4 GB PC3 1600Mhz Memory
I'm having difficulty deciding which graphics card.
So requirements are as follows:
Budget: around £250
Must be able to support 3 x VGA monitors @ 3840 x 1024
Hopefully some future proofing as one day (lottery win) I'll replace the monitors.
I'm guessing that Eyefinity would be the way to go as it only requires a single card although I realise that adaptors (DP to VGA) will be needed.
Any advice would be gratefully received.
Cheers Lee
MSI P67A-GD53(B3)
i5-2500K
Budget: around £250
Cheers Lee
