Graphics card connector- bit confused help
3 Jun 2007
Essex
Hi Guys.
just made the decision the gfx card im gonna purchase tonight but just as I am about to hit submit to purchase i noticed the connectors it has on it have confused me slightly.
The card in questions says it has 1x display port and 3x mini hdmi connectors..
i run two monitors one is DVI and the other has DVI and HDMI so how am i going to connect these up?
Are you bothered about overclocking? If so a Gigabyte Windforce is highly likely to overclock easily to around 1230-50. And it has the necessary connectors.
Otherwise you'll need to buy some adapters.
Is your main monitor 60 or 120 Hz?
both only 60hz
is the clock difference on the windforce going to make much difference? I can overclock but liked the fact the KFA was OC'ed out of the box.
The outputs on this card COMPLETELY baffle me.
Granted, the majority of people buying don't have 3x 120hz screens, but how would it hurt to include nvidia's default outputs? All of the competing top end cards from other brands have them don't they?
Even kfa2s standard non ref 680s have them.
Oh and btw, you won't see a *massive* difference in frames between a lower factory o/cd 680 and this kfa2, the memory is still at stock.
