Graphics Card Cooling Warranty Question???
18 Sep 2005
Hi there, my graphics card went pop at the weekend.
It is a Sapphire Atlantis 128MB 9800Pro and I got it in September 2004.
I am not sure on the warranty provided by Sapphire, but I have had one of them Artic Coolers installed on there since I got it.
Does this invalidate the Warranty (if it is two years??).
you have to put the old coooler back on...but if its still under warranty it will be OK...just dont mention it when you RMA it.
If you do a decent job rebuilding it to original spec, you'll be fine. :p
