Hey,
In short I'm looking for a quiet cooling solution for my graphics card. My computer (in my sig) has always been extremely quiet and temperatures have always been perfectly controlled, my CPU averages at about 30degrees whilst the system temperature is only slightly more.
My graphics card has always been about 57degrees at idle that is until...
A month or so ago somebody pointed out that 57degrees at idle, while not high, isn't that low either and suggested that I install ATI Tray to control the GPU Fan speeds and increase them beyond the stock speeds which I did. To say the least, I'm very glad I did this, at idle my GPU temperature is approximately 38degrees, that's almost 20degrees less!
That's all well and good, but now my computer is louder than a steam train whereas it used to be so quiet that most of the time you couldn't actually tell it was turned on!
Anyway I was wondering whether there were any inexpensive, quieter solutions for cooling my GPU?
For example can you add another fan to it? Maybe a 12cm?
Thanks in advance for any suggestions.
, it does have a OC though. The Zalman is ace.
