Graphics card died. Need help choosing a replacement.
15 Mar 2016
Hey, so my GTX 580 died yesterday with artifacts all over the screen. I need help choosing a replacement card, my budget is £350.
It seems like it's a choice between the GTX 970 or the R9 390X. Never been keen on ATI in the past, but the 390X seems better spec wise. I could also push to £400 if the basic 980 is worth it. I'll only be gaming at 1080p.
Anyway, just some advice would be helpful, thanks.
