Graphics card/display problem
19 Oct 2002
Pembrokeshire
A friend had a problem with his PC, he said that when he turned the PC on there was no display on the monitor.. it was a Packard Bell machine he bought about 1.5 years ago and had a 9600 GS (pci-express) card in it.
I suggested that it might be the Video card and loaned him a very, very basic card to try.. the PC worked fine with this card so assuming it was the Video card he bought a new card an Ati 5750).. Unfortunatly this didn't solve the problem as it also would not output anything to the monitor..
I tried a mid-range card in it that I knew worked and that also did the same, nothing output to monitor from bootup.. This afternoon I found a 7900 GS card and tried that in the machine and it worked OK.
Any ideas what the problem could be ??
I have a feeling it could be something to do with power, could it be that the PSU has developed a fault and is powerful enough to run some cards and not others?? is that a possibility or could it be the motherboard or even something simple? He can't really afford to buy bits to try.
The machine is running fine with my loaned basic card.
Forgot to mention...
Tried his original 9600 GS which was assumed faultly and it works fine in another machine!
