- 30 Dec 2011
- Essex
Hey guys,
Here's some specs I have made up;
Ivybridge Ready Asus P8Z77-V LX Intel Z77 Socket 1155 Motherboard
Corsair HX 650W Professional Gold 80PLUS® Power Supply
Intel Core i5 3570K,1155, Ivy Bridge, Quad Core, 3.4GHz, 5 GT/s DMI, 650MHz GPU, 6MB Smart Cache, 34x Ratio, 77W, Retail
8GB (2x4GB) Corsair DDR3 Vengeance Jet Black, PC3-12800 (1600), Non-ECC, CAS 9-9-9-24, XMP, 1.50V
256GB Samsung 830 Series Slim 7mm SSD Basic Kit, SATA III, Read 520MB/s, Write 400MB/s
4GB Asus GTX 670 DirectCU II, 28nm, PCIe 3.0, 6008MHz GDDR5, GPU 915MHz, Boost 980MHz, Cores 1344, DP/DL-DVI/HDMI
Pioneer BDR-207DBK Blu-ray & DVDRW Writer 5.25" SATA
CM Storm Stryker White Full Tower Gaming Case Cooler Master
Corsair H100
Avermedia C985 Live Gamer HD
Sharkoon 1000 "Golf Ball" Quiet 19 dB(A) Case Fan - 36.7 CFM - The Best of the Best x4
Total: £1,416.65
The only problem is is that it is very expensive as I require a build of £1200 by march next year so unless the prices really go down something needs to go.
I think that my graphics card is too expensive for me as it can run crysis 2 on two screens max settings fine when I will only be using one for the same thing.
So basically I require a suggestion about you guys on what components to get bearing in mind I won't need a hard drive or windows.
Thanks.
Corsair H100
Total: £1,416.65
Thanks.
