GRAPHICS CARD FAN NOISE
31 Jul 2004
I like many others have always been totally confused by varying reports of "fan noise" from the same GFX Cards and I think I have the answer ;)
Given that all modern cards with fan control are silent at idle we won't even consider that.
light-medium loads will cause the Fan to speed up (this is where the problem is)
Some fan motors will start to "WHINE " a nasty cutting sound which may or may not reduce when the fan speed increases further.
Another exact same card exhibits none of this "WHINE" and the fan speeds up to a gentle "Wooshing " sound as the air blows through the cooler !
At higher speeds I don't think people have a problem with loud Woosh, it's the "Jet type Whine" that is the problem
I would also not be surprised if some reports of "capacitor squeal" (really coil whine) are not being confused with this !
Now can we fix it and what causes it ?
basically NO, It's either the Fan motor or the PWM controller making the fan motor "Sing"....We have all used electronic speed controlled Drills, yes ?
What I would say is it seems to be much more an ATI problem than Nvidia
Do Nvidia even cool their cards?
