I have just bought an Acer 22" monitor that runs on its native resolution of 1920 x 1200. I have a good spec system with a 512mb Zotac 8600GTS card, now the problem is at this resolution when using FS2004 I get 25fps where on the old monitor 1280 x 1024 I got 50 plus fps, same in COD4 I get a less smoother gaming performance. So I either go back to 4:3 monitor or up the graphics card. I would like to stay with nvidia.
btw the temps on my 8600GTS are 66 idle and upto 85 under load with stock fan and not overclocked. Is that high??
Any suggestions gratefully received.
Many thanks
My specs:
AMD Phenom II X2 550 (unlocked all 4 cores) 3.10GHz @ 3.60GHz
Gigabyte GA-MA770T-UD3P Motherboard
Corsair Dominator 4GB DDR3 XMS3 PC2-1600C9 Ram
Zotac 8600GTS 512Mb DDR3
3x SATA hard drives
Arctic Cooling Freezer 64 Pro PWM CPU Cooler
XP Service Pack 3
Many thanks
My specs:
3x SATA hard drives
XP Service Pack 3
