I bought a Compaq Presario for a friend, tho it doesnt really do anything like what id hoped for, im just about getting 60 FPS (and that before smoke etc)on CS 1.6!!
Operating System: Windows Vista™ Home Premium
System Manufacturer: Compaq-Presario
System Model: GU668AA-ABU SR5219UK
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ ~2.3GHz
Memory: 894MB RAM
Page File: 1110MB used, 936MB available
DirectX Version: DirectX 10
Card name: NVIDIA GeForce 6150SE nForce 430
Manufacturer: NVIDIA
type: GeForce 6150SE nForce 430
DAC type: Integrated RAMDAC
Display Memory: 313 MB
Dedicated Memory: 122 MB
Shared Memory: 191 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Im guessing theres a bottle neck in either the Graphics card, or Ram (Vista is stupidly thirsty)
Can any1 advise on a course of action?
1) Use the onboard card and buy another put it in the PCIE slot and go for SLI? (no sure thats possible?)
2) Disable onboard and use a standard card. Considering the small PSU, what card would fit? (looking to spend £100?)
Memory: 894MB RAM
You can also do the bundle cheaper
