Hi,
I have a bit of a situation with my graphics cards and I'm looking to upgrade. I was wondering if someone could spec me a card, and let me know roughly what performance boost I would see for the two games I only really plan to play, GW2 and League of Legends. I don't get a huge amount of time to play so can't see me playing anything else, I mainly use this PC for work.
I have crossfire Sapphire 6850 cards at the moment. My first question is, how much do you think i'd be able to sell these for? I have the box etc and know that they are not too old, so maybe I could sell them rather than add them to my collection of "stuff" around the house. These cards on my usual resolution of 1920*1080 struggle a little on GW2 (Although it is in beta, I don't see this changing much). I do also have a second monitor, although even when I disable that one it still stuggles slightly and it causes the game to jerk a little which in battles becomes really horrible.
I'd like to look for a single card solution which would free up my second space.
I *Could* spend up to around £300 I think on a new card, if I sell my current cards whatever I get I can add to the budget. *could* spend though doesn't mean I want to spend every penny for little difference, if one around £200 is similar to one around £300, of course I'd rather not waste money.
Finally, my PSU is only 650w. It's currently running:
G1 sniper motherboard
24 GB Corsair Vengeance 1600Mhz Memory.
Intel 80GB X25M SSD
2X WD Green 1TB hard drives
Crossfire 6850 Graphics cards
1 Blue ray drive
1 CD drive
QPAD MK-85 Keyboard, Sidewinder mouse, Energiser USB Battery Charger, and the 2 monitors which have USB hubs.
I don't want to over do the PSU, I don't know if this comes close to it's limit but I would suspect that it does. The other day my PC did the most worrying thing it ever has, when I turned it on it kept just turning off instantly, the fans would fire up,then went off... it did this a few times until it then booted up. There were no other problems but I thought this was maybe a sign that my PSU is struggling. This was after changing to a new keyboard and plugging in the USB battery charger ( I wouldn't have thought either use that much power but maybe tip it over the edge? )
Anyway, which cards would be best? Do I need to upgrade or is there something else going on which my PC that is causing the problem? How much would you spend and on which card?
Oh, one other thing. My monitor is the Samsung SA950D 27" one, I would like it if it is still possible for this to work in 3D. I'm not sure it works with the NVidia 3d kits or not, I don't really use it to be fair but I'd rather not totally waste the 3D possibilities of the monitor. I've always gone with ATI, but I wouldn't at all mind an Nvidia card.
Thanks,
Intel 80GB X25M SSD
1 Blue ray drive
1 CD drive
Thanks,
