- 29 Dec 2005
Hey,
Well, unsurprisngly posting here about getting a new system. Yesterday i thought i had it all figured out, at least on the graphics front in going for 512mb 8800GT or new GTS model. That was until I figured i'd treat myself to my first 24" 1920x1200 monitor. Now i'm wondering if i need to 'upgrade' my choice of card?
Currently i'm using a 1280x1024 and 1600x1200 CRT's (with a 6800nu). I intend to ditch the 1600 as its pretty much borked and switch to a new 1920 along with the 1280 ( I like the ability of running dual monitors regardless the individual resolutions). Although out of my price range, i'd also like to be able to support a single 2560 monitor, should i ever need to for future work requirements.
So what card should i be looking at, would a 8800GT still be viable?
Do i need to consider switching to SLI? I'd rather avoid it if possible, graphic cards seem to be my weakness in terms of failure rates so having two just doubles the chances of one or more breaking
Something else i'm wondering about is the power usage, esp with SLI. It feels a little extravegant, not mention wasteful to need 1000w just to power ones PC. If I need say a 750w PSU does that mean constant power being used or will it drop down considerably when idle? The reason i ask is i tend to leave my machine on for 24hrs at a time, so would be rather destressed to think its drawing so much power constantly. Any thoughts?
A little background for further information.
My current system P4 2.6Ghz, 6800nu (was OC but had issues) is pretty ample for my general work needs, but now I need a multi-core system in order to run some propritary 3D and really want to start running larger resolutions. So i'm looking at getting a whole new system.
In terms of usage, I'd like to take the oppertunity to get back into some PC gaming, an obvious choice being Crysis, but also eagly awaiting Spore. However I have no qualms falling back to just the 1280x1024 crt for that, if necessary, but naturally would love to be able to play less intensive games (say ET:QW) on the 1920 monitor.
However the main use of the machine is for work, which usually revolves around developing 3D applications, although sadly never to level of the current tech and generally aiming for lower specs than the development machine. In the future this might change, but of particular interest now would be the ability to develop for larger resolutions such as 1920 or 2560.
thx
thx
