Graphics Card for under £100?
24 Apr 2009
In need of a desperate card upgrade, £100 budget. Need some help choosing, the 4850 looks tasty, as does the nvidia 250, but open to anything under my budget
Bought it last week when it was about 6-7quid more expensive, then it proved faulty so its currently been RMAd .
Was a good card when it worked, hopefully the replacement is fine :)
Also consider the 4770, it's almost as fast as a 4850 but runs cooler and uses less power. :)
