Specifically for WOW, 9800GT would be "ok" (ideally should get at least a 4870/5770/GTX260). But in busy area and going on raid with lots of people the frame rate will drop quite a lot, not because of the graphic card, but mainly because of the CPU limitation (or poor coding of the game to be more exact).So the 8800gt is good enough for wow, I am looking for like 50+ fps around and about.
No, what you got in the basket is already capable. A 770 chipset motherboard and a Freezer Pro Cooler and a 955BE CPU. I would get an extra 120mm case fan for rear, as that case doesn't come with one.If OCing would mean having to get better CPU parts and more expensive I don't want to pay much more.
CPU is Very good but the graphics card is no good im afraidIt has the fan holes but no fans?
Also there is a computer I cannot say site but,
# Processor: Intel Core 2 Quad Q9650 3.00GHz Quad Core
# Memory: 4GB RAM (Installed)
# Hard Drive: 320GB Hard Drive Serial ATA-300
# Graphics Controller: ATI Radeon 4350
^^ Fully built pc for same price
Is that better than my build, the quad is not pre-oc'd and I think its a really good processor.
If you read the "Overview" part for the case at the etailor you are buying from, it says "Can take 1x 120mm rear fans (not included)".It has the fan holes but no fans?
Is it possible in todays kind of hardware to get no lag or slowdowns in busy areas? (Bare in mind if the internet connection is perfect)
