- 17 Jan 2006
I am having a bit of a problem with an old computer I am usng for music etc. It's an old P3 866MHz computer which is about 5 years or so old and was running fine.
At the weekend, I moved to a new flat and wanted to set up the computer with an old monitor (also about 5 years old) to use it as an MP3 jukebox kind of thing.
I set the computer up and booted it. The computer seemed to be doing something but the monitor remained in power saving mode rather than switching on. I restarted the computer and this time the monitor came on and all seemed ok.
Yesterday I went to switch the computer on and again, (as I wanted to change the graphics card for another I have which) the monitor didn't come on. After restarting a couple of times it came on but the display was going a bit mad. The memory test and IDE check came up but the text was much bigger than normal, then when it did the IRQ stuff, that was huge n screen and I could only see a small part of the list.
When it got into windows, the screen was not displaying right at all, and it was not refreshing correctly every time I moved the mouse pointer, the screen went all odd and I got a trail of the section of the screen etc etc.
After a few seconds the computer switched itself off.
I switched it back on and while it was doing the same, I managed to uninstall the video card via control panel and restart in the hope that it might boot at a nice low res which would display ok, and allow me to sort it out and put in the different graphics card, which was the whole point of me working on the computer in the first place.
This time however, the problems at start up were the same, ie massive text for the IRQ list etc, then when i got into windows, the display was refreshing correctly etc how it was only displaying the top left corrner of the desktop. I figured this was probably due to the lack of video card drivers so I tried to install the latest Nvidia drivers, however, I was unable to do this because I couldn't see enough of the drivers dialogues to be able to agree to the terms and conditions and hence be able to install the drivers.
I thought I might be able to start up in safe mode to try to install the drivers there. I started the comp and kept pressing F8, this got me to the startup menu, but I was unable to choose to boot into safe mode as the writing was huge like it had been in the memory test and IRQ list!!!
I am now a bit stuck with how to over come this problem. Can anyone offer any help with this???
The system is an old one but when working it does trhe job fine:
P3 866mhz
Aopen AX34 motherboard (possible revision 2 can't remember off top of my head
Aopen PA256 MXII graphics card
Running a stripped down version of XP Pro.
I wanted to replace the graphics card with a Geforce FX5200 (I know it's rubbish but it's more than capable of displaying my player software and it's passively cooled which is useful from a noise point of view.
Any help would be very much appreciated!!!
Valve
P3 866mhz
Valve
A old 9500 Pro or 9700 Pro (those were the days) would be good, and there are bound to be plenty second hand with zalman-like passive heat sinks fitted.
