Graphics card HDMI output question
26 Jun 2004
Hi,
I'm looking for a low profile graphics card with HDMI out capable of Full HD resolutions...but i'll also be using the DVI output on the card to a non HD monitor. The image needs to be duplicated on the non HD screen and HD screen...hope that makes sense!
Is there any card out there that can output the two resolutions at the same time?!
Thanks
As far as I know you have to go with the lowest common denominator when mirroring screens. Otherwise it isn't truly mirroring. The only other way to do something like this is to use a pro video card to down convert the signal on the fly, and even then that would be the kind of thing done using video editing software, not a mirror.
Why do you need to go about it in this way?
