Graphics Card HDTV and outputs twin pictures??
25 Jun 2007
Hi,
I'm after a graphics card for my HTPC that is able to play HD files etc.
I would also like it to be able to output two dipplays but both of the sam thing so that I can either use a 15" tft or my 32" lcd screen at the same/different times depending on what I'm doing.
As its not going to be a gamign rig I'm not looking at spending a huge amount. I've been looking at nvidia but couldn't see much so was looking at
http://www.overclockers.co.uk/showproduct.php?prodid=GX-114-AS&tool=3
Would this do the job and is there anything cheaper?
Thanks
Any graphics card above a 6600 GT can do what you want.
If you're wanting to use Blu-Ray or HD-DVD in the future though your best bet is probably the 8600 GT which is quite cheap. Also, if you do decide to game it's an ok card ;)
