Hi,
My graphics card is a GTX560Ti and I use 2 monitors.
The graphics card has 2 x DVI ports.
The port on the left of the graphics card works absolutely fine, but if I plug a DVI to DVI cable in from my other monitor and into the other DVI port on the graphics card, the picture will just be totally green. The way to fix it is by connecting a VGA cable from the monitor and then using a VGA to DVI adapter into the graphics card.
I can't understand why this is, because if the DVI connection was faulty on the graphics card then the picture would still be green when using a VGA to DVI adapter?
Does anyone know what the problem might be?
Cheers
Cheers
