Graphics Card & HTPC Case
Be carefull full height card support, does not neccesarily mean it wil take all graphics cards. (See my thread as an example!)
Looking at the height dimensions it is close, its a bit taller than mine and so it should fit, but you need to be sure that they are not measuring including feet etc.
I'm not saying it wont fit, but you may want to look into if a bit further.
Might be worth doing a google images search on antec fusion and see if any of the results show full height gpu's installed?
Height wise it will fit, the only thing to check is the length of the card.
I had a Sapphire HD3870 Ultimate Edition in mine and the heatpipes stick a fair way off the top of the card, i could just lock the lid on carefully no problem.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-174-SP&groupid=701&catid=56&subcat=416&name=Sapphire%20ATI%20Radeon%20HD%203870%20XT%20"Ultimate%20Edition"%20512MB%20GDDR4%20TV-Out/Dual%20DVI/HDMI%20(PCI-Express)%20-%20Retail
I could just fit this in and plug in the power with about an inch to spare.
