Hey all,
I have an older but solid system. The details are below. I'm unsure why but I experience micro stutter in many games. Some it's intermittent and restarting the whole system helps, others it is all the time.
I don't see the stutter when running furmark and the CPU is happy being prime95 torture tested.
Subnautica is the game I'm playing and noticed this most. The screen has a micro stutter or even judder at times. I have a few questions about what it could be and what I've tried.
I've tried running this with g-sync and V Sync turned on and off and the issue remains. Afterburner shows I'm almost always running at higher fps than the 75 Hz framerate but I still see micro-stutter and with v-sync and g-sync off even a little tearing where I see horizontal boxes form where the image tears.
I've tried to increase the GPU voltage in MSI afterburner by 20% but that did not improve the situation. Other games, Anno 1800, frostpunk, stellaris also have this stutter but not as often as Subnautica. The MSI Afterburner graphs show the GPU isn't maxing (the CPU seems to be when G-sync and V-sync are off even at 1080 dp) Both GPU and CPU are under less strain with g-sync enabled. The voltage limit graph in MSI Afterburner does jump to 1 even after boosting the power to the card. Which also switched the No load limit from 1 to 0 of course). At these times the GPU is pulling down about 220 watts. If Furmark is sett to the camera moving test I see the stutter too (but not when the camera doesn't move.
The problem persists both at the monitor native 2k (2560x1440) and the easier 1080 (1920x1080). FPS is looking solid at 140 G-sync on v-sync off and 130ish with both off (for some reason, maybe I was just rendering a more difficult part of the game!)
Any ideas on what to check or try? Or what to invest in? I was thinking a 3070 may work but now I've seen the CPU doing so much work I fear it could be a wasted investment.
System:
Graphics card: EVGA Geforce GTX 1080
CPU: I5-6600K overclocked to 4105 (solid overclock doesn't fail a prime95 torture test)
Mem: 16gb DDR4 3900 Mhz
Mainboard: ROG Maximus VIII Gene
HardDrive: SSD (on a pci-e slot I think not a sata cable, at least the system drive is, game is installed on a sata SSD)
PSU: Antec Gold (IIRC I'd need to open the case to check)
Monitor: AOC Q3279WG5B (g-sync compatible 75hz)
Monitor cable: Display port
Please any help!
System:
Please any help!
Thanks though!
