Graphics card issue or VGA issue?
22 Aug 2011
The problem is that whenever I use DVI on my AMD 7850 by Sapphire, the card is absolutely flawless, no problems what so ever, but that means I have to use a monitor that is well, it's not a personal favourite, it's blurred in comparison to my Dell monitor.
But every time I use VGA (My dell monitor only supports VGA), I get horrible lines down my screen while gaming. It is more recongisable on darker backgrounds, but it looks like horizontal lines going vertically up and down the screen kind of behind the picture. It's rather hard to explain.
I was thinking that because this is a newer graphics card, is it just not compatible with analogue inputs (VGA) because both HDMI and DVI work perfectly.
I thought that was the issue also, I tried this on 2 other gamings rigs (my friends and my uncles) and it was the same, I used my card obviously.
Oh, I forgot to mention. If I insert my old 5770, use the dell monitor and VGA cable? The lines disappear.
Yeah, I use the exact same cables on the both cards. It's really strange right? I've tried everything:
Different cables, different rigs, different monitors, the works, I just don't know where to go from here in all fairness. >_>
I'm getting a little lost to be honest :/
So the monitor is fine with another rig or when using another GPU? Correct?
Your 7950 GPU works as DVI and HDMI but when outputting to any monitor from the DVI port to any screen with a VGA input the picture is pants? Correct?
Is the DVI ouput dual link only perhaps? I know that you cant convert DVI-DL to analogue......maybe that's the answer
I'll help clarify, I may of been misleading, I apologise for this.
My dell monitor or any other monitor that uses VGA cables while connected to the 7850 shows lines going up and down the screen while gaming. But if I were to use my 5770, these lines do not appear.
If I use a DVI or HDMI cable on my 7850, the lines are not there, it is perfect.
Your 7850 GPU works as DVI and HDMI but when outputting to any monitor from the DVI port to any screen with a VGA input the picture is pants? Correct?
Yeah, this is correct. I don't understand why it is, maybe like you said, it's dual-dvi only?
edit: The worst thing is though, obviously the 5770 is a much worse card in terms of graphical performance, but even if I did switch back to that card in an effort to remove these lines, I cannot then use my WIFI card as the 5770 gets in the way, as my wifi card is obviously PCI and because of the bulkyness of the 5770, it will not fit in it's slot correctly, so it's just problem = problem = problem, which sucks, lol.
Did you try both of the DVI ports then? Note it has DVI-I and DVI-D listed, the later being digital wont work with VGA (analogue)
Mine only came with 1, it came with 1 x dvi, 1 x hdmi and 2 x mini-display.
I have tried using a standard VGA cable with the adapter previously, I could always try it again though I suppose.
I'll upload two pictures of the DVI - VGA cable and the splitter, just so you have a rough idea of what's going on.
