Hi all,
I'm having a few issues with a new graphics card I've just bought to replace my faulty Radeon 9800pro, as follows:
My PC
Mobo: MSI K8T Neo2 (link)
CPU: AMD Athlon 64 3800+
RAM: 2 x 512mb DDR400 (PC3200)
PSU: 380w, +5v = 35amps, +3.3v = 28amps, +12v = 17amps (link)
Graphics: Powercolor ATI Radeon X1650 pro AGP (link)
It works fine when I just doing basic stuff like web browsing, but while I'm playing World of Warcraft I get to play for anywhere between 5 and 30 minutes before a random crash occurs, such as:
Black screen (games sounds are still heard)
Game freeze (forced to reboot)
System reboot
I have tried many graphics drivers, from old to new official ATI catalysts, and omega drivers, all with the same effect.
I thought it could be the PSU, but aparrently it uses less power than my old Radeon 9800 pro which worked great, and on the box it recommends 300w.
I have run memtest, and all was good.
I have changed settings in the bios, and in the ATI control centre, all to the same effect. I currently have:
PCI settings:
Write ON (tried OFF)
Read ON (tried OFF)
AGP settings:
Read ON (tried OFF)
Speed x8
Fast write OFF (tried ON)
Balanced performance settings, tho I've tried moving all sliders to 'Performance' to no avail.
Hardware acceleration: Full
Write combining: Enabled
WMV acceleration: Enabled
Other strange occurances:
Tried to use ATI Tray Tools to underclock the card, however I cannot change the speed values to anything without graphics corruption, even if I select the default values of GPU: 594Mhz, MEM: 796.5, as soon as I hit 'Apply' my screen corrupts, forcing a reboot. Same happens if I try to scan for artifacts or find a max value for either GPU or MEM speeds.
I have run 3DMark without any problems, however the reading is much lower than my previous, less powerful card.
In my event viewer I have found several entries that show:
Source: ati2mtag
Category: SDTV
Discription: MODE: GXO Execute BIOS Table Error
It's also not just WoW, I play Pro Evo 2009 which shows faults, such as freezes and reboots, but much less frequent.
Can anyone think of a solution, or does the card seem faulty?
Thanks in advance.
My PC
System reboot
PCI settings:
Read ON (tried OFF)
AGP settings:
Read ON (tried OFF)
Speed x8
Source: ati2mtag
Category: SDTV
Thanks in advance.
