Thinking of purchasing this card to replace my old Palit 8800 640MB GTS...
http://www.overclockers.co.uk/showproduct.php?prodid=GX-051-OK&groupid=701&catid=56&subcat=877
If you read the reviews section theres lots of comments about how long this card is. Is it really that much longer than my existing 8800 because I'm slightly concerned about whether or not its going to fit into my case?
The dimensions are listed as 27.5cm but more than once people have said that its over 30cm long! which is kinda worrying.
Thanks.
Thanks.
