Have a "planning for the future" type quandry but with a twist - so all advice appreciated.
I am a gamer currently using an AMD x2 4800+ and 9800gt(I know..). Then I was offered a good deal on a q6600 chip, P35 neo2 MB and 4Gb of Xreaper RAM.
I bought this from someone at work who was happy to let me test before paying etc. The deal went through ok and I built a PC that was stable for about 10 days then started to go downhill (endless messing around - think the MB is playing up - not even got to the stage of trying to OC). I've pretty
much had it now - have just run out of patience so am trying to assess the best way forward.
Anyway, in order to give the q6600 a nice environment, I bought a decent case and PSU plus a GTX560ti.
Given the CPU, I was only going to get a 460GTX but then talked myself into a 560 which turned into a 560ti lol. Now the Q6600 will be taken out of the picture....
So this is the quandry really - I have reasonably decent GPU that is looking for employment ... so do I
1) Transplant my current AMD + mb into the new case with good PSU and use the gtx560i. Is this CPU so old that the 560ti will be underdriven such that I can't tell the difference between it and the 9800gt?
2) Buy a new MB and CPU to go with the GPU.... what would be the "best fit" for this level of graphics card? (I really have no clue which gpu would bottleneck which cpu and vice versa)
The "future" part of this is that ideally I would like to give 3d gaming a go with Nvidia 3d vision. (I will be buying a supported 120HZ monitor later this year if this pans out ok)
So is there any way that this card could handle 3D with the right CPU behind it? If so - which CPU do you reckon? Hopefully this answer will sort of match the answer to (2) above... If it helps I don't mind dropping lots of eye-candy to get a decent frame rate if that's what it takes.
If its not possible, I will go with your "best fit" recommendations and get a non-120 Hz monitor later instead.
btw - budget is £300-350 fpr CPU+MB+RAM - though no complaints if the bill is lower!
Thanks
Thanks
