Graphics card no more then £180
31 Aug 2011
Im looking for a decent graphics card for gaming, preferably suitable for the new Battlefield game that coming out :) the expectations.... cheers fellas and ladies
NOTE: 4GB RAM, I5-2500K 3.4GHZ, AND NO POWERSUPPLY AT THE MOMENT :)
Just bought a 6950 myself, fantastic card for the price.
Should add I purchased the 2GB version.
Thing is, you'd need more than £190 to get a 2GB GTX560Ti as well.
If you really want the extra VRAM then it's probably best to either:
a) Shop around.
b) Go second hand (either second hand HD6950/GTX560 or a GTX400/HD5000 series).
c) Drop back to something like an HD6870.
btw the reason i recommend the MSI one is that the cooler and design is fantastic. the MSI 6950 is also a good choice as it uses a very similar cooler
