Hi all,
Have just upgraded my rig with new MoBo, CPU and graphics card.
When I first set all the gear up, connecting the DVI cable to the new graphics card worked. I then installed some MoBo drivers and the card no longer worked - I had to connect a HDMI cable to the integrated graphics. Since installing all the MoBo drivers and the graphics card drivers, I am unable to get the GPU recognised by my computer - it is not listed under device manager. The fans on the card do spin, and clearly it does work (though I haven't been able to test it in another computer). Putting my old 8800GTS into the same slot in the MoBo works, so the PCIe slot can't be at fault, either. The card does not come up on device manager. I'm really stumped with this, so any advice would be great.
MoBo: gigabyte GA-Z68AP-D3
GPU: Sapphire radon HD 7850
Bios and drivers etc. are up to date
