Graphics card not working
10 Feb 2013
West London
i just got a tech guy to come round and he said the graphics card could be dead as the graphics gets power but no image nd the onboard graphics works do you think thats the case? and also does the graphics card work with the motherboard?
TP LINK TL WDN4800
ARCTIC FREEZER I30
G.SKILL RIPJAWSX 16GB RAM
SEAGATE 7200 12 1TB HARDDRIVE
INTEL I5 3570K
GIGABYTE GA-Z77X-UD3H MOBO
AMD RADEON HD 7970 OC
ZALMAN Z11P CASE
XFX CORE SERIES 650 WATT PSU
heres all my stuff if it aint dead do you recommened i try anything?
Are the 2 6/8 pin connectors inplace?
Is the GPU seated correctly?
What adapter are you using to which port?
I assume all the power connections were connected to the card, try checking the motherboard BIOS revision and see if there is a updated version on the Gigabyte website.
i no its all wires fine and everythings in plase but i dont no what adapter to what port, this is my first build so i dont really understand lol
Just the normal 7970 i no it has 3 fans on the top cost £319 and im using hdmi cable that didnt work so dvi to hdmi as well
I'll repeat which model of a 7970 do you have? Theres no such thing as a normal one because there are different companies selling them, ie a Gigabyte WTF version, HiS IceQ etc
Are you connecting it to a monitor or tv? You might experience some problems connecting it to a tv if you dont have the correct adapter. Cant remember if you need a passive or active one.
Edit. Good point have you updated your BIOS to the latest version.
on the website it just says this
GIGABYTE AMD Radeon HD 7970 OC 3GB GDDR5
erm well since i got it i aint done no updates, as we speak on using the onboard graphics to do all driver updates and windows but how do i do a bios update? ive used a tv and a tv monitor
