Graphics card PCI-E 2.0 – Motherboard PCI-E, Will it work?
11 Mar 2007
Hi,
I’m wanting to upgrade to a GTX 460 Graphics card, but the motherboard I have (in my sig) is only PCI-E.
Will it work OK, or will it be hampered in any way by the motherboard?
Thanks,
Allan.
All PCI-E specifications are designed to be backwards compatible and vice versa, so it will work. As long as the slot is x16, you won't see any performance drops.
