Graphics card power connector
They will be ok to use, they get supplied with cards for instances where PSU's are being used without sufficient connectors.
I have now fitted the graphics card and the power adapter.
Should I have both white connecters connected to the power supply?
At the moment I only have one connected and the card is is installed and working ok nut I am worried I should be using both.
Using both just means you can deliver more current (and so the wires don't melt). As the GTS 450 is a relatively low-power card with a maximum power usage of 105W - it shouldn't need much more than the 75W delivered by the PCIE slot most of the time.
