Graphics Card Problem: Hardware or Driver Issue
13 Dec 2003
Edinburgh
Dear All
I’m experiencing a serious and so far unsolvable graphics card problem.
Screenshot:
1024x768: http://www.redfernonline.com/nvidia/corrupt_screen_big.jpg
640x480: http://www.redfernonline.com/nvidia/corrupt_screen.jpg
This issue only started occurring when I did a complete re-install of windows. Not only does the screen image display these corruptions but the system shows and the signal to the monitor is intermittent. A driver clean then re-install can sometimes solve the issue but not permanently. Sometimes things are fine for days, in one case even weeks, but the issue always recurs. The display appears to be fine when Windows is operating in safe mode. The card is not and has never been OCd.
I have tried:
Re-installing display drivers
Re-installing older versions of display drivers
Using Driver Cleaner then re-installing drivers & older versions of drivers
Could it be a power related problem, a driver issue or is my graphics card just done?
The card is a passively cooled nVidia 6800 from Gigabyte (GV-N68128DH - http://www.giga-byte.co.uk/Products/VGA/Products_Overview.aspx?ProductID=1198 )
The rest of the system is as follows:
Mobo: Leadtek K7NCR18D ProII
CPU: Athlon XP2800 @ 3200 speed
RAM: 1024Mb, 2x 512Mb
Power Supply: Antec 380 Watt True Power
SATA Card: Adaptec 1210SA (Raptor Attached)
HDD1: Western Digital Raptor 36Gb (System Drive)
HDD2: Western Digital Caviar SE16 250GB 2500KS SATA
HDD3: Maxtor DiamondMax Plus9 160GB 6Y160M0 SATA
Sound: Creative Sound Blaster Audigy 2 ZS Platinum Pro (with external box)
I look forward to your help.
Cheers
Jonny
if you see artifacts on the windows logo, when its loading, is the card, on that time is only 640x480, also you could try if you get those artifacts on safe mode.
I had a old FX5600 TIVO-TV tuner and started to make artifact on summer, for overheating. and later it died.
