Hi.
I am in need of some advice. I am 90% certain this is a graphics related issue.
Basically I am having system crashes, no BSOD, just the graphics card fans go to full throttle and the monitor goes into standby. This is a completely random event.
I know it isn't driver related as it happens when in bios and also during POST. It happens also in windows including safe mode. I have tried diagnostic boots and have disable all services other than those required and it has not rectified the problem.
As I said, this appears to be completely random. One day can go by and I don't have any issues. Other days it can take me 20 minutes to get the system to boot into windows. Sometimes as soon as I press the power button the graphics card fans go to 100% and the monitor doesn't come out of standby.
On some occasions, the system almost boots into windows but the graphics cards fans will turn on 100% and the monitor will go into standby but I can still hear the widows logging on tune through the speakers, which would indicate that the system itself hadn't crashed, just the graphics card resulting in a blank standby screen.
Any ideas would be a massive help. I have tried re'seating the graphics card to no avail. I have a 1000w corsair PSU with both the PCIe connectors plugged into the card.
System specs.
Graphics Card - Powercolor HD4870 1GB GDDR5
CPU - Q6600 at stock
RAM - 8GB DDR2
Motherboard - Gigabyte EP45-DQ6
OS - Vista SP2
If any more info is needed please ask as I am desperate to get this sorted.
Thanks.
System specs.
RAM - 8GB DDR2
OS - Vista SP2
Thanks.
