Hi,
I've just bought a new graphics card - MSI 4830 OC 1gb and have been experiencing a problem whereby the screen will randomly flicker on and off black (the same effect as if changing the resolution in Windows) This happens randomly in both 2d and 3d and sometimes there is a a set rhythm of on and off when it occurs - often to the point where the screen predominantly remains black requiring a reboot. Sometimes it does not occur and everything appears fine.
I was previously using catalyst for my onboad ati hd3200 but followed the correct procedure of uninstalling with driver sweeper and uninstalling the card from control panel, rebooting and then reinstalling the latest drivers having selected the correct option off the ati site- I've also tried older drivers incase there was some sort of incompatibility.
I've also noticed this is generally occuring at 1280x1024 which is the native res for my monitor. The PC does not appear to lock up while this flickering occurs and I have checked all connections (it runs via DVI to Dsub convertor) which I've repeatedly tried to ensure is clean of dust and reinserting.)
The 3d itself appart from this problem is fine with no artefacts or discolouring and the frame rates are perfect for the card/games I test.
I'm running (everthing at stock levels at mo but problem occurs stock or oc'd)
2.7ghz 7750BE
4gb OCZ 1066mhz ddr2 reaper
asus M3A78 pro mobo
460w coolermaster psu
1xhd
1xdvdrw
2x 12cm case fans.
I'm hoping the card isn't borked but before I decide to RMA.
I want to see what you guys think...
Thanks!
2.7ghz 7750BE
asus M3A78 pro mobo
1xhd
1xdvdrw
2x 12cm case fans.
Thanks!
