Graphics card question(Dual screens)
That cable Stulid linked (the DVI to HDMI one) will work fine provided the monitor being used isn't higher resolution/refresh then 1920x1200 at 60Hz. If it is a higher resolution/refresh monitor then you should be looking at an adapter for the displayport connectors on the card rather than the HDMI one.
Okay thanks, we are going to go for the same card with the cable as neither of the monitors have resolutions/refresh rates higher than 1920x1200 at 60hz.
