I want to buy a new GFX card. my card isnt doing what I want it to do, and I dont wanna upgrade CPU for a while because of work reasons, I dont have the time etc.
so I wanna get a new gfx card which I can still use if I upgrade in the future.
my sig is my current rig
I was thinking of getting the GTX460 768 mb version
http://www.bit-tech.net/hardware/graphics/2010/07/12/nvidia-geforce-gtx-460-graphics-card-review/12
I was impressed with this review, good temps, low noise, good price performance
which card do you recommend? 150 pounds I would say I want to spend, maybe a bit more.
it has to be low noise, low watt usage ( I have a 600watt good PSU though)
thanks a lot
thanks a lot
